The Fordson Tractor Pages Forum Forum Index The Fordson Tractor Pages Forum
www.fordsontractorpages.nl
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Forest Tractor construction
Goto page Previous  1, 2, 3, 4, 5  Next
Post new topic   Reply to topic    The Fordson Tractor Pages Forum Forum Index -> Ford and Fordson Conversions
View previous topic :: View next topic
Author Message
PostPosted: Mon Jan 25, 2010 11:09 pm    Post subject: Reply with quote
I don't see anything wrong with a cab, as long as you can put it back to original if you ever want to. Interested in seeing the end results. Looks like you are doing a good job from where I sit. Cool Dandy Dave!
_________________
Back to top
View user's profile Send private message
Tiger
PostPosted: Tue Jan 26, 2010 7:07 pm    Post subject: Reply with quote
Sorry, silly me Embarassed
_________________
Another unfinished project
Back to top
aviator
PostPosted: Tue Jan 26, 2010 10:33 pm    Post subject: Reply with quote
Cap installation.
_________________
http://koneenkuvia.blogspot.com
Back to top
aviator
PostPosted: Thu Jan 28, 2010 10:30 am    Post subject: Reply with quote
Cap mounting.
_________________
Back to top
PostPosted: Thu Jan 28, 2010 5:33 pm    Post subject: Reply with quote
Hey, nice clean work. Very Happy Dandy Dave!
_________________
Back to top
aviator
PostPosted: Sun Jan 31, 2010 5:57 pm    Post subject: Reply with quote
the cab floor construction.
_________________
Back to top
aviator
PostPosted: Sun Jan 31, 2010 6:17 pm    Post subject: Reply with quote
thanks Very Happy
_________________
Back to top
aviator
PostPosted: Mon Feb 01, 2010 8:37 pm    Post subject: Reply with quote
Cabin installed, the doors are in place.
_________________
Back to top
Tiger
PostPosted: Mon Feb 01, 2010 9:36 pm    Post subject: Reply with quote
Nice job, you have to take the leyland badge of though Laughing
_________________
Back to top
aviator
PostPosted: Wed Feb 03, 2010 6:35 pm    Post subject: Reply with quote
Hydraulic components.
_________________
Back to top
aviator
PostPosted: Fri Feb 05, 2010 6:42 pm    Post subject: Reply with quote
Hydraulic pump installation 1.
_________________
Back to top
Ian
PostPosted: Fri Feb 05, 2010 7:43 pm    Post subject: Reply with quote
what are you doing with the hydraulic pump exactly ? What's the extra attachment on the PTO for ?
Back to top
aviator
PostPosted: Sun Feb 07, 2010 5:50 pm    Post subject: Reply with quote
Hydraulic pump is installed.
_________________
Back to top
Tiger
PostPosted: Sun Feb 07, 2010 6:07 pm    Post subject: Reply with quote
Nice work, Whats the pump going to drive. Are you going to run any heating to your cab
_________________
Back to top
aviator
PostPosted: Sun Feb 07, 2010 6:27 pm    Post subject: Reply with quote
Should the designated forest tractor Leyland ..? Laughing
_________________
Back to top
aviator
PostPosted: Sun Feb 07, 2010 6:39 pm    Post subject: Reply with quote
Major's original hydraulic pump is a low power loader forest use. Build a more efficient external hydraulic pump. PTO shaft end flange is a hydraulic pump for the installation.
_________________
Back to top
aviator
PostPosted: Sun Feb 07, 2010 6:55 pm    Post subject: Reply with quote
I install the cab heater to heat the engine cooling water. The cab will be very heat of heating the gearbox, but the auxiliary heaters blow is good to keep windows clear so that visibility remains good.
_________________
Back to top
aviator
PostPosted: Tue Feb 09, 2010 7:17 am    Post subject: Reply with quote
Traction device construction 1.
_________________
Back to top
aviator
PostPosted: Thu Feb 11, 2010 11:28 am    Post subject: Reply with quote
Traction device construction 2.
_________________
Back to top
aviator
PostPosted: Sun Feb 14, 2010 5:22 pm    Post subject: Reply with quote
Traction device construction 3.
_________________
Back to top
Kim
PostPosted: Mon Feb 15, 2010 4:39 am    Post subject: Forest Tractor construction Reply with quote
This is an innovative approach and very interesting. I have to ask if you have made plans to have screened/filtered oil going to the hydraulic pump as it looks like you are drawing from the lowest point of the rear end and hydraulic pumps don't like grit, water, and dirt. Where will the return line empty? Please keep the pictures coming! Smile Wink
_________________
Never give up!
Back to top
View user's profile Send private message Send e-mail
Mark
PostPosted: Mon Feb 15, 2010 5:15 am    Post subject: Reply with quote
Kim,
I was thinking the same thing, that's good advice.
It looks like you have been welding for a while, nice job!
_________________
Best Regards
Mark
Always look up He's listening!!
Back to top
aviator
PostPosted: Wed Feb 17, 2010 5:49 pm    Post subject: Reply with quote
Traction device construction 4.
_________________
Back to top
Site Expert Team
Site Expert Team
PostPosted: Wed Feb 17, 2010 8:50 pm    Post subject: Reply with quote
Great design Avitor.
Is the place of the pump not a bit un protected with the hitch so close to it?
Your loosing some of your free play under the tractor, and at the same time you have placed a oil connection under the rear end. Will that not be a problem driving in the forest?
_________________
Back to top
View user's profile Send private message Send e-mail Visit poster's website
aviator
PostPosted: Thu Feb 18, 2010 6:41 pm    Post subject: Reply with quote
Using an external casing aft hydraulic oil tank is in my view a very workable solution. It is true that, particularly in Major's stern casing to cause its own challenges in maintaining the quality of oil. Keychain Case provides a lot of wall surface in a sweat, water, oil mix. So oil change intervals should pay particular attention. Casing below the pump inlet to the hydraulic output jack inside the case rises aft an inch upwards, so it does not take a very light oil. Next to the suction line also has two magnetic plug to remove the oil potential of metal particles. Hydraulic oil return line filter will return to the hydraulic system is the real end of the filter. Casing below the pump connections and the outgoing hose will protect the base armor. Tow hook device is a type of "SA-hook" which is blocked by inhibiting the upper of the cart from rising off the hook towbar's mouth. Therefore, the traction device is introduced into a normal hook hook attachment at a point beyond the rear of ditches, for example, that the crossings can not hit the cart bar hydraulic pump.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    The Fordson Tractor Pages Forum Forum Index -> Ford and Fordson Conversions All times are GMT + 1 Hour
Page 2 of 5
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
