Fordson Standard N water pump
Postby duncan16v » Sat Nov 02, 2019 6:44 am
Hi all
I'm repairing the water pump on my Model N. The front and rear bushes are worn out, and the impeller shaft is very heavily pitted form rust and wear. Looking at the parts available, I can easily get the bushes and a brand new shaft. But how do I get the impeller off the shaft? Is it threaded (left or right-hand thread) or is it push-fit? Any tips for getting it off the old shaft and re-fitting to the new?
Thanks!
Duncan
duncan16v
Re: Fordson Standard N water pump
Postby duncan16v » Tue Nov 05, 2019 8:16 am
Ok! Worked it out. It's an interference fit.
Had the impeller and shaft in an Oxalic Acid bath for a couple of days to clean up the rust. Once the rust was treated, I could see the outline of the shaft in the end of the impeller. Heated the impeller to > 300 degrees then belted it with a drift and the shaft dropped out.
duncan16v
Return to Fordson F, N and E27N Major
Who is online
Users browsing this forum: No registered users and 1 guest
cron
