Fan Belt Size ?
Fan Belt Size ?
Hello , can anyone supply the dimensions of the fan belt for an E27N petrol ( no dynamo ) , thanks in advance , Tim.
Tim,
Fan Belt for E27N without electrics is a Dunlop V513 or Goodyear 313. The measurements are -
Inside diameter 46 5/8 inches. Outside diameter 49 3/4 inches.
Top width 7/8 inch. Depth 1/2 inch.
Angle 44 degrees.
You might care to try a Caterpillar Dealer as quite a lot of the early Cats. used the same belt.
Angle 44 degrees.
BarryM
