E27N electric box mount
Posted: Tue May 12, 2015 8:35 am
by timfarrow
Does anyone have details of the bracket that is used to mount the electric box on a late p/p. This is the box which lays across the steering column at right angles and not the P6 version which lays in line with the column? Also what amperage is required from the battery to power the starter motor.
Tim
Re: E27N electric box mount
Posted: Wed May 13, 2015 4:09 am
by CalGG
Not quite sure what you want here. Are you going to fab up the electrical box mount and need dimensions? It's just a sheet metal triangle about 4 inches wide.
Regarding the "amperage", more is never too much! Just give it a 12V battery that fits the platform!.
Remember to disengage the 3PH hydraulic pump when starting!
Posted: Wed May 13, 2015 12:13 pm
by timfarrow
Thanks. I'll try to fabricate one with this information and reference to pictures in the Condie book
