Major diff plate removal
AndyJB
Post by AndyJB »
Hi-I've removed the plate containing the drain plug from the rear diff but, although removing another 8 bolts holding the larges plate & filter I can't remove the plate, it's free at the front & sides but really firmly stuck at the rear, as though there's a bolt I've missed, any help/advice really appreciated, regards, Andy
CalGG
Re: Major diff plate removal
Post by CalGG »
This is on an E27n Major?
There is a lot of fluid in the rear dif, get out your big pans and buckets for when you get that plate free.
