Hi Dave
You'll have to make a new paper gasket for the
PTO housing. I made one out of an old kraft animal feed sack. Seated it with Wellseal. Worked a treat.
Re the upper
seal (gearbox output shaft
seal), it's available from Silver Fox tractor spares here in the UK for about £9. The lower double-lipped
seal in the
PTO housing I got from a
seal supplier. Once you've got the old one out, vernier the shaft, the
seal seat diameter and the width of the
seal and ask your local dealer for a double-lipped
seal fitting those dimensions. Quite cheap as I remember.
As for getting the
seal out, the upper
seal is straightforward. The photo below shows the
seal assembly held in place by four bolts. The lower
seal is a bit awkward. Remove the plate at the end of the
PTO housing, then drift the shaft out of the housing until the bearings come off their fits. You can then get at the
seal to remove it. It's still a sod to winkle out, but it will now come. The new
seal also goes back in more easily with the shaft pushed back, because the lips of the
seal fit loosely over the splined part of the shaft. Grease the lips before you fit the
seal, so that when you reintroduce the shaft back into the housing the lips slide smoothly into place.
Hope that is helpful.
Best
Adrian
