Yes I bought an after market pipe, unfortunately doe not fit and I need an extension piece bent to a specific shape. Need to find a supplier to purchase pipe and connection fittings and olives.
identify the tractor type
Re: identify the tractor type
I can buy pipe and olives need to find an inline connector to join two pipes. Help needed.
Fuel pipes, olives, hollow screws etc are available to make your own single piece fuel line
https://histoparts.com/toebehoren/en/mi ... nions-inch
Hi Emiel,
Thanks for the info, impossible to find in UK.
Again THANKS.
Gary
Again THANKS.
Gary
Have you asked your local nh dealer? Our local dealer has this stuff on stock. It’s been used at least up to the early 1990’s on ford 10 series.
Hi Emiel,
You have me at a disadvantage, I am not a professional tractor user so, I have no idea about nh dealer.
There is only one diesel dealer in Swansea and I would not go near Shorts of Swanse, they charge you for advice instead of repair.
South Wales seems to be short of information of supply.
Gary
Gary
Gwili Jones in Hafod looks to be sort of local to you. Fast Parts Car and Commercial in Abercarn may have what you need, I know not that close to Swansea but any traditional type of garage should be able to help or point you to their suppliers.
