Power Major Transmission Filter
Anyone know where I can get a new transmission filter for the Power Major? We pulled apart the transmission this weekend and the filter is full of holes and not salvageable. I looked on every site that I have including Agriline and cant find anything.
I am also looking for the two gaskets that go on the bottom.
Does the drain plug have a gasket? All mine had was a copperish ring that didnt seem to being doing a very good job of keeping the fluids in the tranny.
wouldn't it be better with a rubber-steel seal instead of the copper ring? I mean those that are a flat steel washer with like an o-ring inside, usually meant for hydraulics...
If you can't find any to buy just get some gasket paper and get creative with the scissors. There is always sparex gasket sealer, I used that stuff on the lift cover since it would have been a huge gasket to cut out.I am also looking for the two gaskets that go on the bottom.
As for the transmission filter thing, try a breaker.
Re: Power Major Transmission Filter
Learn something new here all the time. I need to get my manuals outl. Did not know the transmission had a filter, where is the filter located?maddyn99 wrote:Anyone know where I can get a new transmission filter for the Power Major? We pulled apart the transmission this weekend and the filter is full of holes and not salvageable. I looked on every site that I have including Agriline and cant find anything.
Gerald
Gman: 1959 Power Major
At the bottom of the rear axle there is a drain plug and two plates. The drain plug of course drains the oil. The first plate allows access to the filter, the 2nd plate allows access to the whole oil pump.Gman wrote:maddyn99 wrote:
Gerald
At least on my Power Major this is what I had.
Thanks maddyn, I have a 1959 power major and have the same filter. You mentioned that your filter had holes in it, it may be ok. The filter in mine is a metal mesh with many small holes and it fits to feed pipe of hydraulics. Also there are magnetic filters, screws, that are also in your picture that would need removing and cleaning. You may want to get more info from others on here, I'm a rookie. I have learned a lot about my power major from this site.maddyn99 wrote:Gman wrote:At the bottom of the rear axle there is a drain plug and two plates. The drain plug of course drains the oil. The first plate allows access to the filter, the 2nd plate allows access to the whole oil pump.maddyn99 wrote:
Gerald
Gerald
Watch out for the dreaded "oil up sleeve" syndrom as you remove the plate and filter
Regarding the washer on the drain plug, always use a copper or fibre one, the ali./rubber ones are for hydraulic lines and I find that, if used on some plugs without the groove at the top for the rubber insert, the rubber tears out and leaks.
If you are worried that the copper one has become hard and will not seal, just heat it up to red hot and allow to cool. It will then be OK for another 60 years.
Yea you better be ready with some extra buckets, a lot of oil will flow when you remove drain plug. I made my own gaskets with gasket material, no leaks.Brian wrote:Watch out for the dreaded "oil up sleeve" syndrom as you remove the plate and filter
I have the two gaskets from the bottom two pieces. They look like they were made out of plastic. Not sure if they were original or some kind of replacement, but both pieces were leaking pretty bad.Ian wrote:when I changed the oil in the back end, I also cut out a new gasket out of gasket paper. Worked a treat, just a little fiddly with the old scissors. Pity no one makes gaskets for these old tractors.
I am going to scan the two gaskets and see what it would cost to have 5 or 10 of them made up. If its reasonable, ill have it done and I will have a few spares and some to pass around or something
Anyone have the top cover gasket or know where to get one? What was there looked like paper and was not salvageable. I have pretty much looked everyone for one, but cant find one. I see the shift cover gasket but not the lift arm cover gasket.
someone actually do gaskets, unfortunately they are expensive :/
Swedish OIE(www.oeparts.se) sells the gasket for the hydraulic lid...
I made my own gaskets from gasket paper I bought at swedish "biltema", a roll of 1000x500x0.8mm thick paper cost about $5 and 1000x500x0.4mm cost me some $3, the OIE gasket for the hydraulic lid cost over $22, so for just a little more time(which I have plenty of) and lots less money(which I have substantially _less_ of), I have gasket paper of two different thicknesses and can make almost all the needed gaskets myself with just a pair of scissors, a small rounded head hammer and a knife (Why yes, I am cheap, I rather spend my money on buying the things I can't manufacture myself and save on things I know I can do myself)
Is this the right gasket? Google Translate doesn't work very well on this website. And i know ZERO Swedish, except what I learned from the muppets
http://www.oeparts.se/Products/Product. ... nId=644180
That's the one gasket yes And as Ian says, gasket-on-tube works good too, just don't apply too much as it will drop off inside the rear end and will just look awful on the outside
you could probably stitch that back together with metal wire. Or replace the wire somehow. I am sure a strainer or something from a kitchen could be cut up and used. And lol I thought the crap in the back end of ours was pretty bad, real sludgy. Metal shavings came out the bottom, and the oil looked like cream !
Hello maddyn, I had problem with getting parts from the local new holland dealer until I found this site: www.agriculture.newholland.com. On the main page of the fordson tractor pages you can find the original part numbers and go to the new holland site. In the new holland parts section you can get a print out of the parts you need. You can take this print out to the new holland dealer, it really helped with the local dealer here. I'm going to have to go into my hydraulic pump soon, if you make any pictures of this when you reassemble please post here. Would like to see what I will be getting into.
Gerald
Gerald
Yeah I have been using that web site for original part #'s.
http://agriculture.newholland.com/us/en is the link I have, yours doesn't work for me for some reason. Unfortunately most of what I need is "No Longer Serviced"
I did find a tractor salvage yard that is fairly close to where I live that uses the part #'s for their inventory.
http://www.eagletractorparts.com/
is the website and you can search the used parts in case you need something you cant find new. Good luck working on your's. It seems complicated until you get into it. Honestly the hardest part was getting the top cover off and removing the bearings from the axles. Everything else is pretty much straight forward.
