6D engine?
CraigScania
6D engine?
Post by CraigScania »
Hi guys i have just got possesion of a 6 cylinder Ford engine.I have 2 Majors with 6 cylinders but they are different as they have shafts from the fuel pumps.This engine has not shaft and has the following numbers on it-688F 6090 GAA anD PB and T4 then 703f-6015-BA hope someone can help identify this engine.Craig
Pascal
Post by Pascal »
Hi Craig,
Maybe the 590e-topic on the "World series"-forum can help you?
Do you have any pictures of your 6 cylinder Majors?
Best regards,
Pascal
CraigScania
Thanks Pascal i will move to that forum and will get pics for you.Craig
You have a 2700 series engine, the others with the shafts are 590 series.
JC
Post by JC »
I remember reading that the 6D is the same as the 590E. Is it?
Yes, you are right JC.
CraigScania
Thanks for that information Brian,i will post some pics for you.Craig
