my unload valve on the diesel major is stuck and i am not sure how to remove it, i have managed to remove top plate and the small piston with the spring but cannot get the valve out beneath.
how can i do this please.
unload valve again
Hello super6. Not sure if your unloading valve is same as my power major. Without taking valve chest off I was able to get mine out with a pair of hemostats, it would fit into the small holes in bottom of unloading valve and with a little preasure it came out. Mine has the little ball bearing between valve and seat, you need to watch for it. I guess the other way is by removing valve chest and going into it from the bottom after removing valve seat. Anyway good luck.
Gerald
Gerald
Gman: 1959 Power Major
