Starter Solenoid questions
FordsonNorway
Post by FordsonNorway »
How does the Starter Solenoid - Button type works?
Is there a button on the Starter Solenoid?
And what is the difference between these two?
Kind Regards Axel
john.n
Post by john.n »
the left hand one is the button type. pressing the button in the middle of the brass ring will close the contacts in the solenoid to turn the starter. i would suggest the one on the right becsuse there is lesss chance of anyone starting it without the key.
hope this helps.
Foxen
Post by Foxen »
I second that about the right one, but the left one is useful when the starter button has broken ;) Still, the left one is "wide open" for humidity, which usually has bad influence on electrics...
FordsonNorway
Thanks for the reply :) .
I have bought a new one because the one on the tractor does not work.
