Clayton Dewandre pump
Postby tractor » Tue Jul 28, 2015 11:00 am
I have a Power Major which has the clayton dewandre pump attached to the fuel pump (from a Thames trader I guess). There is a large nut on top of the clayton pump. Should this be filled with oil, or does it get oil from the engine, or should I leave it alone! Just servicing all the oils on the tractor at the moment, and at first I thought this was where to fill the fuel pump with oil, but I now know otherwise! I put oil in the unit initially but sucked it back out with a syringe before using the engine as I realised my mistake! Any advice is welcomed. Thanks. Ian
tractor
Return to Fordson New Major
Who is online
Users browsing this forum: No registered users and 10 guests
