Major with sawbench
AdrianNPMajor
Major with sawbench
Post by AdrianNPMajor »
Cutting firewood with the Major.
One of my favourite jobs.
Best, Adrian. :thumbs:
oehrick
Re: Major with sawbench
Post by oehrick »
Nice one Adrian
I've still not given up on the idea of driving mine using a prop shaft from the belt pulley
Not that we've needed much heating so far this winter :D
AdrianNPMajor
Hi Rick
How do you currently run your bench - by flat belt? Never used an implement driven this way. Always wanted to have a go at this.
You're right about the weather. I was working in a long-sleeved T shirt!
oehrick
Post by oehrick »
Was by belt, which finally disintegrated hence looking for an alternative. The bench is cast iron and bolted together, this has decided me against the traditional TPL attachment for moving it about, I was given an unused quick release A frame with a couple of the brackets for fixing to implements and am currently looking to make a rear fork / box arrangement to both carry the saw and once set down, bring wood to it - thats the theory anyhow :wink:
AdrianNPMajor
Sounds good. Love the original cast iron benches. I was looking for one when a large 1" thick steel plate came into my life!
I miss the frosty winters. Didn't really know why I was cutting the firewood this time.
chriss
Post by chriss »
Been doing the same with the e27n and flat belt saw benchImage
AXEMAN78
Post by AXEMAN78 »
After seeing your pics Adrian I realise that my Major has the wrong levelling box and lift rod, but still nice to see :D not going to say too much about pto guards though :wink: All the best for the new year Paul
This is a REAL MANS saw bench! :beer: Even has a tungsten tipped blade.
I have a belt driven one here that is about 120 years old. It is solid cast on four wheels and has a rise and fall blade with a position for a wood plane on the side. Weighs in at around a ton.
AdrianNPMajor
Lovely set-up, Chris.
Brian, what fantastic machines. I wouldn't pick a fight with the guys who operated those!
Paul, you do see the lift rods you need on eBay from time to time. Not cheap, I'm sorry to say. Still, the ones you have will work perfectly well until the day you spot the perfect deal. [I actually prefer the lift rods for the Diesel Major - more adjustment available.]
Best wishes to all.
Adrian :thumbs:
RH
Post by RH »
Bit confused on the levelling box/lift rods mentioned here;
Aren't these as seen on Adrian's tractor standard for a Super Major?
Lovely to see these tractors working, and in their working togs!
Adrian's lifting rods are the ones for a Super, the ones in Henk's post are for a Major/Power Major.
Corr :thumbs: ect
oehrick
Post by oehrick »
Some of that Ozzie kindling needs TCT blades Brian, especially the Jarrah! dunno how they managed to saw anything with those exhaust backpressure boxes fitted :run:
My bench is probably a similar age (hell, just worked out that we've had it at least 50 years), made by Reynolds in Southwark IIRC and came out of one of the Wymondham brush factories tho don't recall if Briton or CWS - Dictograph had equipment in both and no doubt Dad intercepted it before the scrapman on one of his service visits.
AdrianNPMajor
Hello Paul
Sorry for the late alert, but this leveling box lifting rod is on eBay.
Best, Adrian.
http://www.ebay.co.uk/itm/Fordson-Super ... 228096240?
