Hi I have a 1959 power with a damaged engine block, I am looking for a reasonable block to replace the one I have from the year 1959 as it would match the age of the rest of the tractor. Just wondered if anybody could help me or advise me of where I may get a block for that exact year.
Many thanks Dan
Fordson power major engine block (1959) WANTED
Fordson Power Major 1959
Re: Fordson power major engine block (1959) WANTED
Hi Dan,
Welcome to the board, might be a good idea to let us know what general area you are in as we cover from the US to Australia and all Europe.
Hi Brian,
Sorry about that I am located in the south west of England but would be prepared to travel
Thanks Dan
Thanks Dan
No problem Dan. The block you want can be from any Major from 1957 through to the Supers with Minimec pumps. In fact the early Supers used the Power Major engine.The later blocks will have a different lift pump fixing and a single bolt fixing cam shaft which means you would need a front mounting plate as well. There are also many industrial and trucks that use the same basic block.
aye up dan
I might have a block that might be ok , its an industrial one so the front plate no good for you , will need new liners , will post some numbers off the block to cross reference, oh buy the way I am in Yorkshire
wayne
wayne
i love driving tractors me!
serial number 1561880
