Unload valve
Unload valve
I’ve just took the lid off my super major and valve was stuck so now it’s removed the oring is no good what’s my best option can I just put it back in with out oring will it all work ok? or try to find an oring
Re: Unload valve
somewhere on the forum Brian advised it's better to leave of the o-ring. I've done this also and the hydraulics did work without it.
Re: Unload valve
Ok thanks valve still seems sticky, when pushed right in but smooth until it gets up to the end
