Transmission leak
Posted: Sat Jun 30, 2018 5:21 pm
Hi guys, I got my 1956 Major Diesel going yesterday and took it for a run, however when I stopped there was quite a bad oil leak coming from a split pin at the bottom of the bell housing. It seems to be transmission oil rather than engine oil as it’s very clean oil but I also noticed the engine oil very thin and the level had risen quite a bit above the max level.
So I am wondering how the transmission oil is getting into the engine? Does the crankshaft oil seal and transmission input seal both need replaced? Also what oil is correct for the transmission? I have 10w30 in at the minute.
Thanks Michael
Thanks Michael
