Super major hydraulics
guduell
Post by guduell »
I have a new major with the stacked additional auxiliary lever and thus independent front and rear hydraulic connections. Good for loader together with tipping trailer.
How should i do this on a super major? The original lever i would like connected to the three point and the auxiliary outlet. And then some additional lever to a front loader that is independent in the rear equipment.
Also I have noticed that two of three four holes for the uppermost pin to the top link are larger and flattened on two sides. How is the original dimension and look of this pin?
1958 Major
1953-59 mix with backhoe Hymas type 3 (project)
1961Selene 4wd (project)
