62 super major hydraulic pump growl
Posted: Sat May 25, 2019 6:30 am
I am still learning on this Fordson for sure !
Tonight I had a lifting boom connected to the 3 point hitch and was lifting a gun safe that weighed exactly 550 pounds.
I had the lift arms as high as they would go, and the pump was growling fiercely. It growled like the pump was deadheaded, similar to a loud bearing that has sand in it sound. ( best way I know how to explain it )
The tractor even smoked, and bogged a touch at idle, more than usual. I was in a position where I had it lifted and was moving the trailer out from underneath it, so it had to stay, until the trailer was clear, for me to lower the load.
Is the pump supposed to growl and almost act like it is putting additional strain on the engine with only 550 lbs on the lift, or do I not have a pressure relief valve set - shimmed correctly or have a problem elsewhere ?
At a bit of a mind puzzler here.
I would think the pump would return the fluid back to the sump, and continue to flow as needed and lock the fluid in the ram, at the heighth desired, without causing what seemed like a deadheaded hydraulic sound.
I sure don't want to damage the hydraulics as I just got them to where they will raise and lower a load correctly !
Thanks.
Thanks.
