Power Major Steering Box Rebuild - Help With Roller Bearings
Posted: Sat May 22, 2021 9:36 pm
by JLworld
I am currently rebuilding my steering box with a new shaft and bearings.
The new shaft fits a treat but I am struggling to fit the new bearings I have managed to get the bottom one pressed in and had the balls sitting in it.
However the top bearing I cannot see a way of installing it?
Any ideas or methods would be appropriated
Will
Re: Power Major Steering Box Rebuild - Help With Roller Bearings
Posted: Sat May 22, 2021 10:34 pm
by Billy26F5
Try fitting the top bearing over the shaft with the balls in place and put the column on, remembering to remove free play with shims.
Posted: Sun May 23, 2021 11:13 am
by Daves rusty bits
Thats how I eventually did mine plus plenty of old partly dry grease to stop the ball bearings falling off.It takes patience and steady hands and I don`t appear to have either. I also filled the box with Land Rover semi liquid grease after the new oil leaked out in no time. Dave
Posted: Sun May 23, 2021 11:47 am
by mathias1
using grease is the way to go to fit all the balls in place
Posted: Sun May 23, 2021 12:29 pm
by JLworld
Would you use normal EP2 grease or a special grease
Posted: Sun May 23, 2021 9:27 pm
by Billy26F5
Normal grease will be fine, but let it get very sticky for this.
Posted: Sun May 23, 2021 10:21 pm
by John b
If you take one of the centre caps off a front wheel there is usually plenty of old sticky grease in there, it's worked for me before now
Posted: Mon May 24, 2021 12:18 am
by Billy26F5
If you do that you might as well adjust the wheel bearings.
Posted: Tue May 25, 2021 6:48 pm
by JLworld
Great managed to do it with the methods you suggested!
