Fordson Diesel/Power Major Auxiliary hydraulic control
Roadless63
Post by Roadless63 »
Some time ago a query went out regarding how to get a constant oil flow from a diesel/power major hydraulic set up, at long last I've unearthed the unit I had in mind, and now I have to try and get the picture to work...
[<img src='http://www.fotothing.com/photos/300/300 ... 8d164e.jpg'>][/img]
Ok I give up, hopefully someone can re-enlighten me on this!
Meanderer
Location: Elora Ontario, Canada (transplanted from Crookwell, NSW, Australia)
Post by Meanderer »
G'day Roadless,
All I had to do to get this for you was to copy the URL address in full and paste it between an open and a closed img code tag.
You can do this when in the edit screen by clicking the Img button and pasting the code. It automatically puts a closing Tag at the end. However, you should aways visually check it before posting. If it doesn't work exactly, edit your post again. (No spaces between tags and URL address of image)
For anyone wanting to know about posting images, links to sites etc.,
the only place I can find to access the Instructions is when you are in the edit or creating a post window. Look down the left hand side to Options and click on BBCode link.
Regards,
Rick
Regards,
Rick
Roadless63
Many thanks for that, it's been a while since I posted a picture and I seem to have lost the knack!
I've not seen another of these units, they bolt to the front of the valve chest in place of the cover plate, the lever flips up and down and allows a constant flow of oil out of a port, I guess it was for one of Mcconnells attachments such as a hedge cutter etc.
