Where does (or should) it go?
The pipe goes into the head and then.........
FMD Injector bleed off ?
Re: FMD Injector bleed off ?
Thanks.
Mine is blanked off......
Consequences if any?
If it's blanked off at the fuel tank there will be no leaking out of the tank to spite the pipe not being there and a bit out of the banjo, if the banjo is plugged however, the build up of fuel could either leak into the engine oil or affect the injector opening pressure, the tank will also leak a bit. So you should really get this working properly again to be on the safe side, not too diffivult to do that.
Someone has plugged it both ends.
Been like it for a very long time.
Will buy a pipe and get it back in service.
Some people.....
Some people.....
