NP Super Major Adjusting draft control linkage
Posted: Thu Nov 30, 2023 2:43 pm
by rosie01
Hi all - i am working my way through the set up process on the hydraulic linkage on my NPSM. Bit confused about the gap i need to adjust between the circlip and the front end of the draft control plunger. Text in the manual says 0.200" but the diagram shows 0.020". Can anyone tell which is the correct measurement i need?
Many Thanks Rosie
Re: NP Super Major Adjusting draft control linkage
Posted: Thu Nov 30, 2023 2:48 pm
by Billy26F5
Are you sure you're looking at the NP manual? It says 0.010" there.
Posted: Thu Nov 30, 2023 8:29 pm
by rosie01
Hi Sandy - The manual i have is by TMM Manuals and covers all Major Models. I am looking at section 256 of the manual which is the NPSM (allegedly). I think its a typo in the text. Which manual are you referring to? On the same diagram in my manual there is another mention of a 0.010 feeler gauge inserted between the main control spring housing face and the draft control plunger. If i could work out how to stick a picture of it on here that would help - i do prefer 1960s tech.
Many thanks - Rosie
Posted: Thu Nov 30, 2023 8:52 pm
by Billy26F5
I'm referring to the original Ford manual, here's the NP hydraulics section: https://www.fordson.se/6B_Hydraul_Suple ... 25-050.pdf
Posted: Fri Dec 01, 2023 9:52 am
by rosie01
Thanks Sandy - your manual is far superior to the one i have. I'll stick it on my christmas pressy list and hopefully santa will oblige!!
Posted: Fri Dec 01, 2023 3:56 pm
by Billy26F5
fordson.se have the whole manual in bits, I think there are other places that have it as one, all in pdf which makes them easy to find some of the time. Not so good when you're actually doing things.
