Hi-Lo Lever
Posted: Mon Apr 15, 2024 11:01 pm
by Old Hywel
Any significance concerning one-piece levers as against knobbed levers?
I thought they changed in later years, but I’ve recently seen photos of early Majors with the larger, screw on end.
Re: Hi-Lo Lever
Posted: Tue Apr 16, 2024 8:50 am
by Billy26F5
The early levers had a large separate knob and were fixed on with a pin. these had a bad habit of getting very loose, so were replaced with the clamp type in around 54, this was the one piece type, which was replaced by a two piece clamp type with the Power Major with a smaller knob. Ebro never used a two piece knob, the lower dash needing a larger hole to allow it through.
Re: Hi-Lo Lever
Posted: Wed Apr 17, 2024 7:41 pm
by Old Hywel
Thanks for the comments. My query relates to the knob at the driver end.
Some are cast as one piece (similar to starter lever), others have a much larger, screwed-on composite knob.
Why the difference?
Re: Hi-Lo Lever
Posted: Tue Apr 23, 2024 8:34 am
by Billy26F5
I don't know why they changed the knob in 54, they must have thought the one piece casting would be cheaper. Anything post Power Major however must have a separate knob as otherwise the lever won't fit through the dash.
