If so, which filter head are you using?
I'm told an MF35 conversion will fit the Dexta?
Hi Chris,Cvans wrote:It's interesting you would bring this up today as I just installed a kit purchased off of ebay some time ago. I was plowing yesterday when the original filter canister started dumping the engine oil on the ground.Fortunately I caught right away. I haven't run it yet today as I need to go to town and get some more oil. I'll try and report back tonight with how it worked out and maybe a photo of the install.
Any time I can help just give a shout. I don't know all the answers but I'll be glad to help if I can.Many thanks for the info.
Should the oil filter have a by-pass valve?Cvans wrote:At this time I'm using the one that came with the kit. I don't think a vertical filter will drain back like a horizontal filter will. I'll watch the oil pressure gauge the the next time I start it and see how fast the pressure comes up. I know the next time I install a new filter I will fill it with oil first. Took a little bit for the pressure to come up after changing oil.
