Still having no luck starting the Dexta. Carried out compression test, not the best results.
No1 140 psi added a drop of engine oil to top of piston tested again 220 psi
No2 300 psi Happy enough
No3 100 psi added oil 120 psi Not good.
Another question
How much of a spirt of diesel should come from injector feed pipe, just getting a small spit of diesel.
Which of the engine rebuild kits is the best? Guess its time for a rebuild after 56 years.
Compression test
Re: Compression test
a small spit of diesel intermitally from each injector as engine is turnned over
is normal, cant really help with engine kit i suppose they all much the same
someone eles on here may know which is best type to go for , good luck either way
sky blue
sky blue
You may find when you take the head off that it needs the head re-conditioning and the bottom end is ok
Hi.
It doesn't matter how much diesel you have getting in, with those compression figures you're never gonna get started!
Whip off the head and check the valves and seats, if they're ok, it will be out with the pistons and liners I'm afraid...
Bepco do the best engine kits, if you can find them..
Mark
Mark
Mark
I agree whip off the head , it is easy access on the dexta once the bonnets off.
do the injectors protrude thru the bottom of the head once its off ,so don't put it down on the bench , right way up because it will damage them , put it on its side or remove them first .or am I thinking of a different engine all together
have a look at the valves then report back
loads of helpful knowledgeable chaps on this excellent forum to help
on the plus side at least there only 3 cylinders to worry about
