pump or hydraulic lift problem?
Postby skipdow » Sun Nov 17, 2019 8:17 am
My dexta recently has gotten very noisy with the hydraulics and is weaker in lifting implements. Is this likely to be the pump(I have a spare parts dexta with a good pump) or the lift assembly at the top? How do I test the pump or is there an obvious fault that has those symptoms?
Thanks for any suggestions you may have...
skipdow
Re: pump or hydraulic lift problem?
Postby Tubal Cain » Fri Nov 22, 2019 7:55 am
Providing that the oil level is correct, it could be that the suction filter is dirty, to inspect it you have to lift the top cover off.
Gerald
Tubal Cain
Site Expert Team
Site Expert Team
Return to Fordson Dexta
Who is online
Users browsing this forum: No registered users and 3 guests
