HI
My super dexta is reluctant to start at the moment. New battery, but the heater plug cable needs a new spade connector (easy to sort) and the knob doesn't click when pressed in on the injector pump.
I was told that it is dependant on the pull stop mechanism somehow
Any assistance on resetting the fuel button will be gratefully received
Compliments of the season to you all
Alex
cold start extra fueling knob
Re: cold start extra fueling knob
Hi. Make sure stop button is in and open throttle fully out.
Cheers Les.
Cheers Les.
Thanks Les
