Is this battery tray available new anywhere?
if someone has an old tray and clamp that is complete, please let me know.
Firewall and Battery Carrier & Clamp
The original plate that sits under the battery can be had 2nd hand if you're lucky - could try Malcolm Hipperson. I don't know of anywhere to get an original clamp other than make your own eg as per Gerald's earlier post. Stefan also made one.marlyman wrote:Is this battery tray available new anywhere? If someone has an old tray and clamp that is complete, please let me know.
I think I'll get a plastic tray, eg as per Gerald's post: There is a small battery box on the Towsure web site, internal measurements 190 x190 x 285 long, cost about £12.00 which looks a perfect size. Then I'll just use a couple of webbing straps right around the battery and base plate, which seems to be a simple and effective hold-down that I've seen on other Dextas.
All the best,
