Dexta Register.
trigger
dexta register
Post by trigger »
1962 Super Dexta
S/N - 09B?23655
Engine - 1609546
Clutch- L11H
Gearbox - L4H
Left Rear Axle - L11H
Right rear Axle - K23H
Lift Cover - L6H
lbonlake
Post by lbonlake »
1961 Standard Dexta
S/N 957E92094
Engine 1492762
Clutch housing L14F
Front tran gear box J20F
Rear tran gear box L18F
LH Rear Axle L14F
RH Rear Axle K29F
Hyd lift Cover L6F
Elbie
TonyDexta
Dexta Register
Post by TonyDexta »
1964 Super Dexta
S/N - 09D926142
Engine - 1645894
Clutch Housing - 4A16
Gear Box - 4A14
L/H Rear Axle - ?
R/H Rear Axle - H5H
Hyd Lift Cover - 4A14
Tony Dexta
Shropshire
England
bobfaecullen
Re: Dexta Register.
Post by bobfaecullen »
1958 Standard Dexta
Serial No:- 957E 834
Engine No:- 1401766
Clutch Housing:- A15B
Gearbox:- B10B
Rear Axle:- A22B
Hydraulic Top:- B5B
Right Axle:- B10B
Left Axle:- B12B
Registered for road use 23rd May 1958
pgreenan
Re: Dexta Register.
Post by pgreenan »
Dexta Standard
Engine No. 1481171
Chassis/Tractor No. 957E84482
Gearbox No.957E7005
Gearbox cast T4, D*SF
Engine casting 2GKN1272 G/0 280098F
Tractor is mainly yellow in colour blue engine, trying to find information on my dexta in culding year if anyone could help?
Registration 8694PT. Thanks.
Nick
Re: Dexta Register.
Post by Nick »
Standard Live drive Dexta
Engine no : 1448725
Serial no : 957E 47998
Gearbox : 957E 7005 T4 A21D
LH axle : A22D
RH axle : A26D
Clutch : A21D
Hudraulic Top : A26D
Registration : Yet to be found
Wee59dexta
Re: Dexta Register.
Post by Wee59dexta »
1959 Standard Dexta, Tyrone Northern Ireland:
Registration Number: VZ 5887
Engine Casting: D149
Serial : 957E 35683
Clutch Housing : H22C
Gearbox : 957E 7005 T3 J22C
Lift cover: H16
Left Axle : H11C
Right Axle : H23C
On the Flange Below the tractor between the sump: 0830225V2
gunner312
Re: Dexta Register.
Post by gunner312 »
1959 Dexta
SN: 957E34718
Eng SN: 1435799
Tran Casting: 957E7005
Hyd Section : 957E4024T
Left Axle 957E4013
Right Axle 957E4012
keithmbell
Re: Dexta Register.
Post by keithmbell »
STANDARD DIESEL DEXTA with live drive.1959 (assumed)
TRACTOR SN : 957E 29231
CLUTCH SN : 957E 7505 (CASTING : C23C)
GEARBOX SN : 957E 7095 (CASTING : D3C)
HYDRAULICS SN : 957E 4024 (CASTING : B27C)
L/H TRUMPET SN : 957E 4013 (CASTING : C19C)
R/H TRUMPET SN : 957E 4012 (CASTING : D2C)
HYD TOP SN : 957E 501 (CASTING : C25C)
ENGINE SN : 1430115 (CASTING : C0280098F)
Currently in lots of bits and getting smaller all the time!
MarksDexta
Re: Dexta Register.
Post by MarksDexta »
1961 Standard Dexta
Serial number 09A316482
Engine number 1497948
Clutch M24F
Gearbox P19F
Rear housing P20F
Left Axle M6F
Right axle L5F
Trevorthetractor
Re: Dexta Register.
Post by Trevorthetractor »
Chassis No. 957E38920
Engine No. 1548365 (appears to be a later Number, maybe a replacement engine)
Clutch housing J17c
Top cover J25c
Gearbox H5c
Axel N/s K12c
Axel O/s K17c
Can somone date my dexta please :?:
60dexta
Re: Dexta Register.
Post by 60dexta »
Standard Dexta
Serial No: 957E 47***
Engine: 1650***
Clutch Hsg: A8D
Gearbox: M27C
Rear Housing: Haven't found it yet
Hydraulic Cover: A1D
LH Axle 'Trumpet' A4D
RH Axle 'Trumpet' A11D
Rob
Dexydog64
Re: Dexta Register.
Post by Dexydog64 »
Standard Dexta 1958
Ser No 957E4898
Engine no 1405401?
Bell Housing C31B
Gear Box D1B
Back Axle D1B
Axle Ext LH D2B
Axle Ext RH D2B
Road Reg Jan 1959
Les bryant
Re: Dexta Register.
Post by Les bryant »
1963 Super Dexta
S/N 09c734289
Engine No 1618417 A103
Clutch housing A3J
Gear box N22H
Diff housing M19H
R/H Axle A11J
L/H Axle A22J
Hyd top P27H
Spare Hyd top M17H
geoff
Re: Dexta Register.
Post by geoff »
Geoff
Malabar, Fl
1959 dexta # 957e 32755
Engine # 1433873
Simms pump # spe3a605590
Hydraulic lift casting d3c
Clutch casting f15c
Left axle b27c
Right axle f19c
bell housing f20c
Coblentz
Re: Dexta Register.
Post by Coblentz »
196? Super Dexta?
S/N 09C734131
Engine 1618231 A33
Clutch J10H
G'box A22J
l/h axle P11H
r/h/ axle P11H
hyd top K23H
v8devon
Re: Dexta Register.
Post by v8devon »
1959 Dexta
S/N 957E 26865
G/Box B26C
L/Axle B26C
R/axle B25C
Reg 855 YUL
Brian Cox
Re: Dexta Register.
Post by Brian Cox »
by Brian Cox , Perth , Scotland.
1962 Super Dexta
ser.no. 09B 730114
engine 3711130
clutch housing 7505G
gear box housing N23H
hydraulic lift L2011
right hand shaft M23h
left hand shaft P4H
blue is the colour
stugreen
Re: Dexta Register.
Post by stugreen »
1958 Fordson Dexta (Standard Drive) living in Cumbria
Serial no. 957E5359
Engine no. 1403389
Clutch. D2B
Gearbox. D8B
L/H Axel. D1B
R/H Axel. D8B
Hydraulic Top. A7C (original one is D2B but a snapped stud and a farmer using a welder as metal glue made it very nasty)
1958 Fordson Dexta Standard Drive
252YUH
1959 Fordson Dexta Live Drive
Yet to find its number plate :(
Phil C
Re: Dexta Register.
Post by Phil C »
Hi All I am new to the forum, and have just purchased a 1962 (going by serial No) Super Dexta
Serial Number 09B715964
Engine /no 37111310R I think difficult to see
Clutch casting H14H
Gearbox H14H
Hydraulic casting N12H or H12H difficult to see
Rear axle right H13H
left H13H
nrb01525
Re: Dexta Register.
Post by nrb01525 »
Here are the numbers from my Super Dexta from nrb01525 in Bedfordshire England.
Serial Number 09D905182
Engine Number 1645124
Casting codes as follows:
L/H Axle 4A10
R/H Axle 4A9
Diff. Housing 4A8
Gearbox 4A7
Clutch Housing 4A9
HYdraulic Casting 3M17
Mustard
Re: Dexta Register.
Post by Mustard »
Mustard, Darwin
1957 Fordson Dexta AKA Sexy Dexy
Serial No 957E 7005
Engine No 1449498
Hydr. lift A12D
Gearbox A14D
Left Axle shaft 957E4012 - A18D
Right Axle shaft 957E4013 - A19D
burrII
Re: Dexta Register.
Post by burrII »
Mustard wrote:Mustard, Darwin
Serial No 957E 7005
Engine No 1449498
Hydr. lift A12D
Gearbox A14D
CHECK THESE NUMBERS OUT !! is it rare for matching numbers ? :scratchhead:
Ford Dexta AKA blue
Serial No 957E 7005 T3 H8F
Left axle shaft 957E4013 T3 H12F D1
Right axle shaft 957E4012 T4 H13F
Engine No ( ? ) 148746
fuel pump ( ? ) Simms SPE 3A 605593
generator Lucas 22756F 12 72 C40T 12V
957E 7505C F23F T1 this number is located on rightside casing (trans ?) lower than and behind starter
on the banks of the Savannah
MichaelS
Re: Dexta Register.
Post by MichaelS »
1960 Dexta
Sn 957E-69098F
EN G0280098F
Engine block casting # 2GKN1372
"It Shows" Captain Ron
highangle
Re: Dexta Register.
Post by highangle »
Year 1964 Super Dexta 2000
S/N 09D92? 23
Engine GKN 1372 1C
Clutch 4D14
Gear Box 4D2
Rear End 4D8
Left Axle 3L15 B
Right Axle 3K3
Hydraulic Top 3M23
Hood badges say Ford 2000
