When idling my dexta it sounds strong and even, without any surging, and when driven in any gear it starts out strong but in a short time it acts like it wants to die. I have found that if I hit the primer button (under the fuel tank) a couple times it will rev up again. It acts like it is lacking fuel. I have cleaned up the air filter so I don't think air intake is a problem. My primer has the fuel line to the intake manifold removed so would pumping the primer move fuel to the injector pump? If the fuel pump is working why would pumping the primer have any effect?
I have thought that perhaps the lines need to be purged but it starts and idles fine. There is only a problem when running in gear especially uphill.
Also my lift pump does not have a priming lever. It looks the same as all the pictures I've seen of the original except for the absence of this lever. On the top it says "Made in England" around the edge and on the top of the two knobs it says AC and YJ.
Sorry for the lack of pictures as I forgot to bring a camera when I was last at the farm.
Dennis
Engine stalls
Hi Dennis,
Usually when this problem occurs the filter gauze in the tank is clogged.
There is only one method to solve this.
1 Leave out as much fuel as possible from the tank by disconnecting the line between the fuel tap and the fuel lift pump.
2 Unsrew the fuel tap from the tank and clean the gauze and the tap thorougly.
3 Clean out the fuel tank with a hot water pressure washer (steam cleaner). Let the tank dry, best results you will get when you dry the tank with a hot air gun (used to scrape paint of windows etc.)
4 Reassemble, fill up and bleed the system. To be sure fitting a new fuel filter is a wise idea.
You are showing all the syptoms of fuel starvation. I would suspect that the filter in the fuel tank tap is blocked. You need to take the tap out and clean it. Also you may need to change the paper fuel filter.
When you push the primer you are injecting neat diesel into the manifold. That is why you get an increase in power. This is not a good idea as the fuel is not atomised. Normaly, when you use the primer it should be after heating the heater element for 40 seconds. The diesel then is burnt in the intacke manifold and does not enter the cylinders as a liquid.
Too much pumping of the primer can lead to a hydraulic lock and damage to the pistons and rings ifthe diesel is not fired by the heater.
