New kid on the block?
No!!!! Its Dotty after her "Nose Job"!!!
We are all loaded up for our trip tomorrow with Dotty and Ransomes TS1015 calling at Mikes on the way to Brimfield and Mark, Edward and Brian.
Same trailer as we brought Oscars Dexta home to Barry but this time the plough sticks over the back by about a foot.
Petrol Dextas are of course longer
Brian's been giving his baby girl a face lift evidently and has not been telling us anything about it. SHAME ON YOU BRIAN!!!! Now we need to see the pictures of all this work and narration of each episode.
Any body out there want to second my motion?
She looks ideal Brian, I can't wait to see what she says about her new make up in the Dolly report.
See ya
Mark
Mark
All I did was fit a new cowl and paint the rusted areas. I had the wings welded so had to cover up the weld marks. The wheels you may remember were a horrible yellow and pretty rusty.
She is by no means perfect, I made some errors and got runs on the wheels, but she looks tidy. I still have lots of work to do like get the lights repaired and back on, but at the moment, its work in progress as I find time.
A comment on another subject raised. I fitted a new light/ignition switch last year. On Sunday it broke internally and I now cannot turn on the ignition. The barrel is cheap soft plastic and is no way up to the job. I am pretty sure it was a Sparex one but I will find out so we know what to avoid.
And no it is not a "German" nose job. She was a New Zealand tractor with headlights mounted outside the grill although she has the brackets in there. Export tractors could have either. Dotty and her sister both had silver grills (as they should have) and external headlights with bars on the grill. So she is looking like her original self.
Jos, she had a vertical exhaust and no evidence of an underslung. If you mean she has no hole in the bonnet, all petrol Dextas have the elbow like a Major. Mine is a Fergy one as the one she came home with was a welded up bend fitted to a Cortina rear silencer and tail pipe!
She was used with a mid mounted mower, brackets are still attached, so there was nowhere for the exhaust to run as the drive shafts and mower brackets to the back axle are in the way.
Ignition Switches
Yes pleaseBrian wrote:I fitted a new light/ignition switch last year. On Sunday it broke internally and I now cannot turn on the ignition. The barrel is cheap soft plastic and is no way up to the job. I am pretty sure it was a Sparex one but I will find out so we know what to avoid.
Also any anecdotal evidence on the longevity/ serviceability of combined light/ignition switches vs separate switches as for later Dextas and Supers and Majors(?) appreciated.
All the best
Ben
Hello All,
Should the grilles be silver on all blue & Orange Dexta's super dexta's, wether they are export or not? Mine (Diesel super Dexta) had orange grilles with the headlights mounted on the outside(I am in Ireland so I wonder if it is classed as an export model? hence outside mounted lights), but there are no "ornaments" on the grilles, should there have been?
Thanks,
Niall
Thanks,
Niall
Niall,
Please don't start the grill colour debate again!! Its been some months now and I though it had gone away!!!
All Super Dextas should have silver grills. No Super left the factory with Orange grills.
All export tractors had the bars BUT some home market tractors had the lights fitted externally at customers request. These would not have had bars fitted.
I have seen three industrial, home market Super Dextas recently, with no lighting and all have had the bars.
Brian,Brian wrote:...Jos, she had a vertical exhaust and no evidence of an underslung. If you mean she has no hole in the bonnet, all petrol Dextas have the elbow like a Major. Mine is a Fergy one as the one she came home with was a welded up bend fitted to a Cortina rear silencer and tail pipe!....
I was not thinking about an underswept due to the bonnet but due to the outlet-collector. Opening down-wards looks to be the typical shape for underswept... but han you should have some more evidence like the brackets to support the outlet.
Rgds
Jos
Jos
So the colors from the grill, Today I found this on Marktplaats.nl (something like eBay) http://www.marktplaats.nl/index.php?url ... older.html
Export Dexta Orange wheels/ Silver grills and Blue bars
regards Frans
1964 NP Super Major
1964 NP Super Major
