Has anyone else had this problem?
Got a new light switch (without key) but find it doesn't fit very well - it wobbles in the panel. The reason - it has 2 rivets which stick up and prevent it sitting snugly underneath the panel. In fact when fitted, it is decidedly gash.
According to the parts list, there should be a 'Seal', item 11, on top of the switch, between switch and panel, presumably to take up the gap and hopefully prevent the rain running down inside the panel:
Has anyone come across a suitable seal/rubber washer?
Maybe another DIY job?
Any advice appreciated,
Wobbly Light Switch
Wobbly Light Switch
You seem to be having all the electrical luck today, can you not 'washer' it out? I think ours had some thin rubber which is probably the seal you talk about.. Looks like you'll need to get the knife out and cut a new one.
Rich
Rich
Yup! I feel a trip to the rubber shop coming onEddieJ wrote:You seem to be having all the electrical luck today, can you not 'washer' it out? I think ours had some thin rubber which is probably the seal you talk about.. Looks like you'll need to get the knife out and cut a new one.
Ah ha thanks Stefan - very interesting. You have the real thing!Stefan wrote:Hi Ben,
my light switch is a never used original part and as you can see, it doesnt't has rivets. Just a few flat welding points.
Regards Stefan
Reproduction parts just aren't the same. Cheap and not always cheerful
I'll make me a rubber washer to take up the gap.
All the best,
