See that is used with Ransomes Sportcutter units,
What sort of grassfields do you cut with Molly.
How easy is steering with the front wheels inside out.
she is used soley for cutting the outfield of my local cricket club using as you noticed a ransome triple gang mower
as regards the front wheels all i can say is you live and learn, when the better weather comes! i will turn them round
tony
They look like car tyres Tony, You may find they chafe on the axle. Dotty had similar on when I got her home and someone had put washers behind the wheel studs on one side and fencing wire on the other.
hi brian
i found that out last summer had a puncture had it repaired replaced the wheel what i thougt the right way carried on grass cutting only to find i could'nt turn the corners
tony
