i cant find any wire hose clips large enough for the rad hoses and the pipe from aircleaner to inlet manifold. has anyone ever found a supplier of these?
john.n wrote:i cant find any wire hose clips large enough for the rad hoses and the pipe from aircleaner to inlet manifold. has anyone ever found a supplier of these?
Have you tried Agriline? They advertise them.
All the best,
found old 20 supply many different sizes of wire hose clips. got a couple of leaks though. quite large leak from the lower hose conection to the pump. and a smaller one on the bypass hose. any thoughts on how to fix this?
john.n wrote:found old 20 supply many different sizes of wire hose clips. got a couple of leaks though. quite large leak from the lower hose conection to the pump. and a smaller one on the bypass hose. any thoughts on how to fix this?
Thanks for the tip about Old20.
Can you establish why your hoses are leaking - eg are they bedded onto corroded/rough surfaces?
