Injector information
Hi all
I have been checking my injectors over ready to get them setup/tested and I have found that I have 2 different coded injector nozzles.
I have
2 off NH153A
1 off NH389
So....I am assuming this is not ideal!
I have
2 off NH153A
1 off NH389
- Site Expert Team
Checking my notes I have Dexta nozzle has 2 x 0.35 mm holes and the Super Dexta has 2 x 0.32 mm holes. The opening pressure is given as 160 atmospheres.
I would take the injectors to your local injector/fuel pump specialist and have him fit new nozzles and adjust the atomising pressure. It should cost you about £60.00, which in the long run would be cheaper than refurbishing your old nozzles!
Gerald
Gerald
Thanks all
I have called my local diesel setup for prices for injector refurb (County Diesels at Syston) and they want £47.50 plus the Vodka And Tonic each!
Has anybody any experience of:
http://www.southerntractorspares.co.uk
As they offer an exchange service at 21 notes each which sounds excellent.
I think they are OK.
Do a search on here as I think their injector refurb has been mentioned before. I have bought parts from them, inc a duff heater switch which I'm waiting for them to replace.
- Site Expert Team
Yes they were.marcusgs wrote:Hi, Russel,
Were those from Southern Counties?
I am thinking of sending some there too.
Regards,
A nice job done, recommended by me (I checked the pop pressures and spray pattern on the tester at the heritage centre this afternoon).
New nozzles fitted, bodies cleaned and reset.
Gets my
Just had our injectors serviced, cleaned and reset at a local diesel specialist. One inject required a new nozzle. It all cost £60 collected them yesterday after they had them for one day.
Rich
Rich
Hi ChrisChris Ivin wrote:Hi Eddie,
Where did you get yours serviced, I'm local to Coventry and mine need servicing.
We went to Keresley Garage Coventry. Its on the Tamworth Road on the Fillongley side of the Royal Court Hotel.
Details:
Keresley Garage
Tamworth Road
Coventry, CV7 8JG
Phone: 024 76332642
Pretty good service but we haven't refitted the injectors yet. He charges £15 for clean test & reset then £15 per nozzle if required so this may cost £90 if all three injectors are in a poor state but ours were functional.. A local garage saves the faffing with postage and helps the local economy.
On another note I got a full head gasket set for £28 inc VAT from Sutton & Sons near Nuneaton and it was off the shelf! They do a lot of tractor refurbs so check out the website:
http://www.fsuttonandson.co.uk/
Thanks Eddie,Hi Chris
Details:
Keresley Garage
Tamworth Road
Coventry, CV7 8JG
Phone: 024 76332642
Much appreciated.
Chris
Brailes, UK
"Dexta's rule the World!"
Brailes, UK
