is there a gasket between the aux. service plate and the top cover, when i removed my service plate for the first time there was a gasket there and i reused it as i could not get a new one anywhere i looked.
So should there be one there, and should i use some of the gasket in tube type stuff on it?
I think this could be my problem now, as i put a small bead around the outside of the plate before reassembly and i think it may be preventing the Orings do their job.
