I have a NP 1984 Super dexta and wondering if someone could tell me what is the diference between the radiator on a Super Dexta and an ordinary dexta and would the radiator from an ordinary Dexta fit into a Super Dexta
Hi johnjt, i take it you ment a 64 as this was the end of the dexta production, the dexta rad will fit superdexta but idont think the superdexta rad will fit into the dexta cowl, as the dexta rad is a bit smaller, you are better if you can the right rad for the right make.Gerry
