Hi everyone!
Looking for some help restoring a super dexta.
The plate that is bolted on the back of the engine for holding the air filter can and throttle linkage there is a s shaped bracket that bolts on behind the air filter to the head the question i have is the air breather pipe from the rocker cover the bracket that holds the pipe is it bolted behind or on top of the s shaped bracket?
If somebody had a picture or the answer that would be great.
AIR BREATHER PLATE
AIR BREATHER PLATE
Brendan Mc Caul
Super Dexta
Refurb
Super Dexta
Refurb
Have you seen the parts list downloadable from www.fordson-dexta.de ?
Reference to this might answer your Q, or at least enable others to understand your Q more clearly.
All the best
All the best
Does the photo below help?
It's a standard Dx rather than a Super, but I expect it's the same.
All the best,
All the best,
