I am trying to fit an automatic pickup hitch and part of the process is removing the lift arms and replacing them with the special ones needed to accomodate the hitch and other implement. On the face of it this should be a simple task, however , time has sealed the arms solid. Has anyone else carried out this task before? if so are there any tips to pass on?
I have just spotted the post from "Hiking Bear" on this very topic. What is a "Puller" and where might I get one?
Removing the lift arms
Stefan had to cut his off - painful. See www.fordson-dexta.de
i had this problem when trying to get aset off mine , they can come off easily or be right pain, mine were the latter. after using wd40 about 2cans ,heat ,beating with a sleage hammer and trying a puller i ending up cutting them off , if you have to do this hopefuly not , be careful not to cut the splines on the cross shaft , i used a 4inch grinder with the thin cutting blade .i cut nearly through and then split with a chisel, the ouside edge isnt to bad to cut but in near the cover shoulder can be trickey as the blade might also nick the cover .
Good luck GERRY
Good luck GERRY
i probley woud have to do the same again , but only as a last result best to try the heat an if you have axces to a good powerful puller this the way to go , even when mine were cut throught they still were very tight , thankfuly the liftcover and linkages were not damaged when i was was thumping at them i think this was more to do with luck ,
Gerry
Gerry
