towing
Hi ithink what trailer you can pull depends on tractor & trailer, i have an old type wooden trailer , its a single axel, and when fully loaded ithink it should be 3 to 4 ton, my dexta pulls it with no bother on the road , but i suppose the tractor will let you know if she is under powered or not for what ever load she is pulling, the same with lift if the front wheels come off the ground its probley to heavy,
Is with a braked or unbraked trailer? The law may have changed since our handbooks were written?Dunggatherer wrote:Somewhere in the paperwork i think i read you can pull up to 6 tons,but please be careful,at some point you want to slow down too,and i don't know if the brakes are really up to this.
Yes sounds like the same idea. The usual arrangement over here on trailers up to a few tonnes is a sliding mechanism in the trailer hitch that presses on a lever when the trailer tries to overrun the towing vehicle, that operates cables to apply the brakes. No hydraulics other than a damper in the hitch. Reasonably effective provided everything is free and sliding.JC wrote:Are over run brakes the same as the ones we call surge brakes over here. Does it have a master cylinder on the hitch?
Your electric brakes sound like an electric version of above. Presumably there is a sensor in the hitch that measures movement or compression to feed the brake controller?
Or does it operate on an 'ON' / 'OFF' principle, eg from a brake light switch?
electric brakes sound like they could be really effective have never seen a trailer fitted with them. only problem i can see is that the handbrake makes the pedals drop (if the switch is fitted here) when applied that might cause the battery to go flat when the engine is not running? i was going to fit a brake light switch wired for the trailer socket or if i could fit dual filament bulbs i would use wire them into the side lights as well, just dont want to addd extra light to spoil the look of the tractor.
many thanks
many thanks
A wire from the brake light switch supplies power to the brake controller when you push the brake pedal. A pendulum inside the controller senses the inertia of the slowing tow vehicle and applies more or less voltage to the brakes. If the vehicle isn't moving, there would be no inertia to send voltage to the brakes, so it shouldn't drain the battery if it's parked with the brake pedals locked. You could wire it through the key switch to be sure. It doesn't sound like electric brakes are as common over there as they are here, so maybe its not as good an idea as I thought.
- Site Expert Team
Details of electric brakes can be found here
http://www.maybricks.co.uk/trailer-brakes.html
I have also read that under new legislation to be introduced shortly overun brakes will only be legal on centre axle trailers such as caravans or car trailers.
To tow 3.5 ton safely under the conditions described the ideal system would be to have a coupled brake system as fitted to some Landrovers which legally allows them to tow up up to 4 tons, which would be similar to that fitted to modern tractors.
Gerald
Gerald
i have been looking into buying all the bits for towing, unfortunatly i need a drawbar, so i was going to buy some steel to make one up. other problem i have come accross is the pins with a ball hitch on the end. the highest rated one i could find was 2500Kg and i will be pulling upto 3500Kg.
any help welcomed.
Many thanks.
any help welcomed.
Many thanks.
Do you have to use a ball hitch? Why not a pintle ring - more usual on agricultural trailers?john.n wrote:i have been looking into buying all the bits for towing, unfortunatly i need a drawbar, so i was going to buy some steel to make one up. other problem i have come accross is the pins with a ball hitch on the end. the highest rated one i could find was 2500Kg and i will be pulling upto 3500Kg.
What's also worth remembering is the max towing weight or (max weight been towed) should also include the trailer. I would not feel safe towing 3and a half tonne's behind my Dexta without a braked trailer, she may pull it OK but i doubt the tractor brakes would be safe. much better with a braked trailer and a 50mm balljohn.n wrote:i have been looking into buying all the bits for towing, unfortunatly i need a drawbar, so i was going to buy some steel to make one up. other problem i have come accross is the pins with a ball hitch on the end. the highest rated one i could find was 2500Kg and i will be pulling upto 3500Kg.
any help welcomed.
Many thanks.
