I just bought a 2nd hand fan shroud on ebay which was quoted as having the correct pn for standard Dexta. 957E8146B, see below
I was assured by the seller that it is correct for a standard radiator with 14" core, which is what mine is.
I haven't got it yet so haven't tried to fit it.
However the 'new' shroud is clearly different from my old tatty one:
The new one appears to be taller with the lower mounting holes further up from the bottom.
Does anyone know if the shroud design changed during the life of the Dexta?
TIA
