Stabiliser Bars
niallsdexta
Stabiliser Bars
Post by niallsdexta »
Hi All,
I am sorry this may have been asked before, but could someone please give me the length hole centre to hole centre of the straight stabiliser bars for a super dexta.
Also i see some of them have a bend in the ends and some don't. does anyone know which is correct for a 63 super dexta.
Thanks,
Niall
I don’t know what I am doing!
River
Re: Stabiliser Bars
Post by River »
If my memory is right, a straight bar is correct, I think the cranked bars were for the 2-3000s, length can be checked by having a cat1 linkage drawbar on and measure when its centralized, hope this helps, if I can find a Dexta stabilizer I will post a pic.
Lesfen
Re: Stabiliser Bars
Post by Lesfen »
From as much as I can see from a couple of parts book drawings... the ends look straight.
But, there seems to have been an change from a round pipe type stabiliser bar to a flat iron bar sometime between 1959 and 1961 even though the parts numbers are identical (E133-WP-9).
Les
niallsdexta
Re: Stabiliser Bars
Hi All,
Thanks for the info, but I would like to make myself a set of these bars so dimensions would be great if anyone has a set.
The dimesions I require are:
1. The size of flat bar used.
2. The distance between centres of the holes please.
Thanks for all the help,
Niall.
GERRY
Re: Stabiliser Bars
Post by GERRY »
Hi nail , the one i use is
800mm between holes
10mm thick
40mm flat
idont know what kind of steel it is made from ,
hope this helps GERRY
