Cold Starting a Dexta - A novel solution!
Saw this Dexta at Hullavington a couple of years ago and the owner explained how it worked.
Lite up a gas blowlamp, open the tap that is plumbed into the inlet manifold, point the flame into the cup and start it!!
That is what I call lateral thinking!
Hold heater for 40 secs. Push prime button and press starter.
In cold weather open throttle quarter open. Press in cold start button on pump. Repeat above. (Minimec Pump models).
The time for the heater was moulded into the original heater covers.
Cold Start torch
Few years back on this forum I reported that before I rebuilt my Dexta, prematurely worn out from "the ether-baby" process, the only way I could start it was to remove glow plug, put a propane torch in the intake and when warmed, crank till it started.
When I pulled the pistons, ring-bits fell off like shell corn. Problem was while I had the rebuild kit on hand, did not have time to stop and get er to the machine shop. After finishing clearing my pasture, I tore it down and upgraded to 152 pistons. It was worn to point of weak. Bottom end was fine. However, one or two times, worn out like this I felt it rev up, as oil rings fell off like shelled corn, too.
Wayne
Wayne
Hi everyone I have just joined this forum it looks great. This novel idea was mine. It worked really well when I was in my garage/shed I would use a hot air paint stripper in the bell mouth and on the rare occasion that I was not near an electric supply in the morning the only time that I needed it I would use a blowlamp. It was perfectly safe and so easy to use as you are standing on the same side as the start lever.
Cold start
Hello. Mike here from Australia.
We use a can of areo start; You spray a little bit into the airfilter inlet as you are cranking the engine and it starts straight away.
Mike,
The Royal Society for the Prevention of Cruelty to Dextas will be banging your door down at 3 am tomorrow!!!!
EasyStart (ether) is the worst thing you can ever use in a Dexta. It causes ring, piston and con-rod failure. There should be some pretty horrific pictures on here showing some of the problems caused.
All Dextas will start OK if the primer and manifold heater is working and later ones with the Minimec pump even had an excess fuel button.
Ether is the biggest NO-NO i can think of.
Welcome to the board by the way.
Why do you need it?
If the original system is working you get fire in the intake manifold drawn into the combustion chambers, perhaps more effective than glow plugs. The weakness in the original system is the priming pump and, as Stefan has shown, this can be overcome with modern materials, the heater element is available.
Just my opinion.
Just my opinion.
