Hydraulics
peter
Hydraulics
Post by peter »
Hello Brian, last year i cleaned and overhauled the hydraulics system of my
Ford dexta , because the arms would only raise if the main control lever passed the top. Perhaps you remember the problem.
With your help i did the overhauling. When i was werking with the Dexta this summer the liftarms slowlly drop as the weight i carried decreased. (watertank). This happens in position and draft control. The hydraulics show no sign of correctioning the drop. Do you thinking i have to do the settings again?
Lifting the arms is more or less ok, althoug the liftarms seem to react a little late from the lower position.
Correcting the drop is ok with the main control lever.
I hope you can help me again. How can you see if a followerpin is worn out?
Peter
