Iwas driving along the road in the snow with a heavy weight on the rear linkage and went over a hidden bump, then link arms dropped about 4 inches measured at the ends. I could not get the arms to raise to the fully raised position. the draft control rocker had been pulled back by the jolt and once returned to this position the arms would once again raise to the fully raised position. It was as if thee draft control had over riden the position control. or am I going to have a bent internal linkage?
any advice or comments?
Regards,
