Hydraulic Loader Cylinders
strawhouse
Post by strawhouse »
My Dexta has an Allied loader installed on it. The seals on the hydraulic lift cylinders are starting to go. Instead of rebuilding the cylinders I have the option of purchasing new more reliable cylinders that are the same price as the rebuild. The new cylinders are larger in diameter than the stock cylinders which means more hydraulic fluid. How much fluid can the Dexta handle? When the loader bucket is down the fluid goes back into the Dexta so I am worried about overfilling and then running dry.
Andrew
