glow plug testing
glow plug testing
Could anyone please tell me if you connect a multimeter between the tip of a glow plug where the live comes in and the body of the plug where it screws into the manifold should there be continuity? Many thanks. Richard
Re: glow plug testing
Hi, Ive never tested mine (because it works), but yes there should be continuity across it, but not a dead short. Put your multimeter on ohms setting, you should have a certain amount of resistance, like every heating element should when working ok.
Are your symptoms a) glowplug not working or b) blowing fuses/melting wires?
Connected the glow plug today across a battery charger and it glows red after 40 seconds so I guess its ok. Thanks for the reply.
Hi.
It really should glow red a few seconds after you put 12v through it...
Mark
For the sake of 20 pounds I just ordered a new one on ebay. Should improve starting.
take plug out, and connect to battery. after about 2 seconds it should be warm and after about 4 seconds it should be glowing
