We are currently upgrading the board. You might experience some issues while using the website.
As for this: New members will not be approved during this process.
Thanks for your understanding!
With Regards,
The Fordsontractorpages management.
Playing with some designs for PTO handel remodel
Winchester
Post by Winchester »
As I have mentioned before I don't like the clutch pedal when it's in stage two for engaging the PTO. It rides way to high.
But I do need to have it set up this way, so I can start and stop the snowblower. I thought I play around with a override system
with a handle to make starting and stopping the PTO a bit more easy.
Do you think this will work?
Tom T. Winchester
Little did I know that all those days passing was life itself!
