As explained in previous posts I have recently bought a Dexta with a loader which is a great little tractor.
I found a couple of problems that the seller has fixed however it is hard to start in the cold and takes 2 or 3 attempts even when using the primer and glow plug.
The seller has agreed to do a compression check on the engine but he has not got a compression tester. Does anyone know were I can hire one with an adaptor suitable for a Dexta.
Andy
