It's time to change the back axle oil.
First I have to drop the old oil. But the male square drain plug is nicely obstructed by the brake cross-shaft and the drawbar bracket.
I've measured the drain plug and it appears to be a square of side 9/16" (14.25mm) . So I need a square female socket of that size to get it off - which seems to be a hard socket to find
How do you get your plug out - is there a crafty way.....?
TIA
Changing rear axle / hydraulics oil
- Contact:
Re: Changing rear axle / hydraulics oil
I had to empty mine out last week, I just used a normal shifter
Go down to Halfords and buy a "one size fits all socket". Its the one with a load of needles in the barrel. Worked a treat for all my square plugs!
http://www.ebay.co.uk/itm/like/36085631 ... 0&ff14=108
Looks crafty indeed!Jerry Coles wrote:Go down to Halfords and buy a "one size fits all socket". Its the one with a load of needles in the barrel. Worked a treat for all my square plugs!
But is there enough space beside the cross shaft to get it on? I see magic socket is 1"OD so must be tight on space.
Of course I could just drop the cross-shaft ... only two bolts but they've not been off for 50 years...
googled on Jerry's magic socket but it seems quite pricey £20+
So I just loosened the two cross-shaft bolts and hey presto, some oil started to drip out!
So I guess the holes are drilled all the way through the main back end casting.
So I could just drain the oil out through one of these bolt holes?
Anyone else do this...??
hi ben
I had to lower a home made draw bar bracket to get at the drain bolt , in the nettles b4 I dared move the beast to drop the water out that had separated
I blew a hole thru the channel iron , to access the drain b4 I bolted it back on , I did have to drop the brake cross shaft it was seized up ,but I cant remember if oil came thru the drillings sorry ,
I think my plug is a hex not a square so a socket fits , or maybe I replaced it with a hex for ease next time , I think its the same small plug as a fergie .
it will be a tapered plug wont it , gas pipe ,BSPT ???
tom
tom
So no prob dropping the cross-shaft, no nut or anything to come loose on the inside of the back end - that would be embarassing.tom lad wrote:... I did have to drop the brake cross shaft it was seized up ,but I cant remember if oil came thru the drillings sorry....
the cross shaft for the brakes / hand brake , ? no problems as I recall ,every one of the pins and pivots had seized on mine so had to be heated and freed off indervidualay .
as long as the bolts , set screws , don't snap then should be straight forward , prob worth some copper slip on re assembly? make it easier next time eh
i'll have a look under my s dexta tomorrow if I remember , to refresh .
good luck
good luck
OK thanks for info.tom lad wrote:the cross shaft for the brakes / hand brake? No problems as I recall, every one of the pins and pivots had seized on mine so had to be heated and freed off indervidualay.
As long as the bolts , set screws , don't snap then should be straight forward , prob worth some copper slip on re assembly? make it easier next time eh
good luck
Been topping today, so will drop the back end oil after next day's work, and lube the brake cross-shaft whilst I'm at it - no grease nipples on mine.
- Contact:
Many thanks for the foregoing, this morning I was in the fortunate position of attempting to remove the drain plug from my 1964 this morning lying on cardboard over concrete in full daylight with no rain falling.
Bliss.
I am pleased to report that a 15mm open-ended spanner, encouraged by No. 2 Medium Claw Hammer, unscrewed the plug just so and I even managed not to drop the plug in the drip tray.
Thanks again.
Bliss.
Thanks again.
Richard
All manner of things shall be well.
1964 Super Dexta
1960 LE
1969 T100C
1981 T140ES
1993 MT350
All will be well and all manner of things will be well.
1964 Super Dexta
1960 LE
1969 T100C
1981 T140ES
1993 MT350
